Replacement Fogs
Replacement Fogs
I was looking at getting the Poison Spyder Brawler Lite front bumper with the holes for factory fogs, problem is I don't have fogs. So what can I get that will fit in the hole that isn't the OEM? I was looking at the KC Lzr LED lights but i dont think they will mount.
Link to Delta's site/fog light
http://deltatechindustries.com/site/01-3039-JKX
can the light fixtures be replaced in those delta units, I'd like to find a way to use some Bosch Compact 100 fog lights. the bosch are the best ones I have come across but mounting in the stock bumper will take some work?
Don't forget to ask about wiring and such, what fuses it comes with and so on and if you need to buy anything else to complete your project.
I called up Delta and they were very helpful. The guy told me that I could replace the crummy stock fog lights with theirs, run the heavier gauge wire to the fuse box from the lights, replace the relay and fuse and I'd be good to go.
Update. Bumper mounted, Delta's mount fine in OEM bumper, but not in the PSC bumper. The OEM has more give/slop in the setup which the delta lights need. Obviously there is no give in the PSC bumper :-) . The Delta setup needs slightly larger brackets to fit into the PSC, I will put something together in a few weeks.
Also, the Delta does not use any OEM pieces to mount the lights on either bumper
