Reverse Camera - Wire
I installed a reverse camera which displays on my JVC head unit. There is a feature that allows me to view it when the vehicle is in reverse. It worked great when I had my factory amp in (with the Metra harness). I removed the amp and installed 2 other amps. Now the reverse feature does not work. Anyone know which wire I could hook up to the Metra harness to make the reverse work again?
I Just Installed Mine The Wire Is White With A Gray Stripe, I Connected To It Under The Pass Side Kick Panel The Harness Is In There, Have To Dig For The Wire...to Verify Take Off The Brake Light 4 Screws And Look At The Wire Running To The Reverse Lights...
