Rigid SR-M flush mount?
Old Jan 28, 2014 | 02:31 PM
D!CKS GARAGE's Avatar
Default Rigid SR-M flush mount?
Ok so this might sound a little off, but has anybody ever thought about mounting a pair of SR-M's on the front grill in the space next to the turn signal/marker light below the headlamp?
The space is big enough for the flush mount SR-M or possibly even the flush mount Dually's.
I am thinking of mounting them here with the angled adapters to keep the light down low, and kick it out the side more than the factory fogs.
Only issues I might see is: clearance... Is there enough room behind the plastic grill panel? That one is easy, go out and measure. The FM Dually's have a 3 3/16 depth.
Second I plan on eventually putting a PS Brawler Light bumper with the brawler bar... Will the tube of the brawler bar interfere with foreword projected light to the point of making them useless? Easy one for that would be to not get the bar on the bumper.
Any thoughts?
Currently being monitored by the NSA.
Old Jan 28, 2014 | 02:54 PM
karls's Avatar
The bar probably will block the lights. Most of the normal stingers block the regular headlights to a degree (part of the reason I got rid of my stinger.
It would be a little awkward to use the flush mounts and attempt to angle them. I did just a slight angle with these lights in the rear valence of my GTI. It works, but getting the angle is a little weird.
Old Jan 28, 2014 | 03:18 PM
They make angled adapters for all the flush mounts...
I dont need a 45 degree slant, or another set of stupid bright lights, just something to fill this void a bit and kick a bit more out the sides:
Thats the stock headlights + fogs + all 5 KC Pro-Sport HID's I have as overheads.
