Rocker switch panel
Old Nov 28, 2008 | 09:54 AM
thejtr's Avatar
Default Rocker switch panel
What are some other brands of rocker switch panels has everyone used? I'm looking for pics and suggestions. I've seen the Daystar, Moroso and Cooltech's. Any other ones? Also, I have a six-speed and I've read that the boot hits the daystar rockers. Has anyone installed the switches in the spot between the vents (if you don't have auto windows)?
Thanks JK'ers!
Jtr
Old Nov 28, 2008 | 05:32 PM
w squared's Avatar
I have an LCD screen installed between the two vents. Then again, it's just glued there.
That said, I've had the dash off, and between the vents is one of the few places that has a bit of depth available to you. Measure twice, dremel once
Old Nov 28, 2008 | 07:31 PM
jmat1980's Avatar
You can fit 3 or 4 rockers on the dash to the left of the steering wheel. Open the door and pop off the cover on the side to access the area behind for easy wiring and there is also access to a hole that goes through to the engine compartment...
Old Nov 29, 2008 | 04:18 PM
tambil68's Avatar
Try Carling technologies.
www. leapfrogstudios .com
Old Nov 30, 2008 | 11:51 AM
Choppus's Avatar
otrattw.com has the carling contura switches.
Old Nov 30, 2008 | 03:34 PM
tambil68's Avatar
Yep, but the site redirects you at the moment to a temp site. They are rebuilding the site.
Awesome switches though.
Old Nov 30, 2008 | 04:08 PM
nosmr2's Avatar
Those are some nice lookin' switches.
