JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   JK Electrical, Lighting & Sound Systems (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/)
-   -   RR A-Pillar + Switch Install in a 2011 (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/rr-pillar-switch-install-2011-a-187667/)
Nomadr Jul 23, 2011 07:37 AM
Seems I keep getting lucky and finding things that won't fit properly in a 2011. Wondering if anyone has modded and installed the RR A-Pillar switch pod successfully in a 2011.
The problem is mainly with the bottom of the pod. There is only one clip on the 2011 - which is at the top of the pod. The 2011 has some tabs that fit into the dash instead of the bottom clip.
Here are a couple of pictures that show the final fit. I will probably install and hope that there is a new one for the 2012 that will fit the 2011. I needs me some switches :)
Stock A-Pillar -
https://lh4.googleusercontent.com/-t...0/IMG_0545.JPG
RR A-Pillar -
https://lh4.googleusercontent.com/-R...0/IMG_0544.JPG
https://lh4.googleusercontent.com/-d...0/IMG_0542.JPG
https://lh3.googleusercontent.com/-Y...0/IMG_0539.JPG
4cyturbowrx Jul 23, 2011 09:32 AM
I put one in my 11.... Fits fine
Nomadr Jul 23, 2011 09:49 AM
So maybe I am lucky to have a mid-year change? Was yours smooth at the bottom like the RR shows, or was it jagged like my stock one shows? Wonder if I was sent the wrong pillar.
CrystalRubi Sep 18, 2011 01:25 PM
The RR A-Pillar doesn't fit well in my 2012 either. I don't care for the gap at the bottom and could live with it but, mine rubs the door when closed. The bottom sits out enough the door hits it. I put the single factory clip on the bottom of the RR A-Pillar hoping that would help but it didn't. I don't really want to cut my factory A-Pillar but that looks like the only option in my '12 Rubi. I like the idea of the Daystar mount above the rearview mirror that others have done so that may be another option. Hoping RR will make an updated version for 11+ JKs.
Ryan0260 Sep 18, 2011 01:34 PM
How does the color match up? Looks like it is a gray color...
greenenvey Sep 18, 2011 01:39 PM
Same problem with my 2010, it bowes i'n on the window side, and hits the door when I close it!!! I emailed them and sent them several pics like they requested, then they forgot I sent them and lost them so I sent them again!!! Andy they said they would take care of it and I never heard from them again after about 4 emails sending them all the info, and a copy of invoice........ So I just chalked it up to one more product that didn't fit correct with nothing done about it!!
Rubi Driver Nov 10, 2011 05:17 PM
Any update on this product? Some sites are now listing it as "2007-2012". I assume it's the same product, just a change of the years in the marketing materials...
Nomadr Nov 10, 2011 06:29 PM
Originally Posted by ECHO (Post 2646635)
It does look a few shades off in color .. or is it just the lighting ..
I painted it with some Rustoleum satin black and it matched up pretty well.
Nomadr Nov 10, 2011 06:57 PM
Originally Posted by ECHO (Post 2646745)
Nice.. I like the design of it.. Post up some pictures when you have the switches in :thumbsup:
I went with an air gauge in the bottom and two switches - one for compressor and one for lights.
Showing gap at the bottom - used pipe insulation to fill it in a bit.
https://lh6.googleusercontent.com/-T...0/IMG_1372.JPG
The flash makes it look like a bigger color difference than it looks in normal light.
https://lh6.googleusercontent.com/-8...0/IMG_1376.JPG
antonioso Nov 11, 2011 10:46 AM
[QUOTE=cp08jk;2540058 I like the idea of the Daystar mount above the rearview mirror that others have done so that may be another option. Hoping RR will make an updated version for 11+ JKs.[/QUOTE]
Is it on their website? i didnt see it :thinking:
© 2026 MH Sub I, LLC dba Internet Brands
