Running wire
So I am re-locating my license plate to my tire carrier. All is well except I want to run the cable through my bumper and this is proving a PITA
Been following this write up:
https://www.jk-forum.com/forums/show...=license+plate
Problem is don't readily have a vacuum that can work and do not want to buy one. The hanger approach I have tried and failed any ideas?
Been following this write up:https://www.jk-forum.com/forums/show...=license+plate
You could go to a hardware store and get a line puller (for running wire through conduit), they usually are made out of sprung metal and if you can get it started into the hole you want to turn into it will go. Some pictures of exactly what you are trying to do may help us make some better suggestions.
