Select Increments Stealth-Pod
Is anyone using this enclosure in their JK Unlimited?
http://www.quadratec.com/products/14136_80X_PG.htm
I already have a RF 10" sub and an amp, so I would only need the enclosure.
I am wondering if you can hear/feel the bass with the top open/down/off?How much space does it take up? Does it move/rattle/fall off or out the mount when off roading? Just exactly how secure is it on the tailgate? If not this, what are you useing for a sub?
It is a little over a cubic foot. I'm working on a Kicker set-up, hope to have more info soon. In stock form (Legacy Speakers), you can hear with top on, off, down w/ & w/o rear seat (2dr). Using with Duster Cover w/o top & rear seat works best. A bit more kick w/ less distortion with volume at 15+.
With Paragon closed, I have not taken it off-road yet, but no rattling on Philadelphia's pot-hole riddled streets.
I wish the Infinity Basslink would work for me, but I can not have it perm mounted and it will not fit under the seat. I am a cyclist and need the cargo space for my bikes, so being able to remove it is ideal. If I could find a good one, like the basslink, that would fit under one of the front seats, that would be better...
If the SI Stealth-Pod sounds good and will not fall out/off, then I think it will work OK for me.
Soooo, anyone using it yet??
hey jk kj .....
do you have any problems with the basslink i seen on crutchfield some horror stories about it dying ?!?!?!?!?!?
i dont want to break windows and go deaf i just want a little more punch
i used powered bazooka tubes before but i didnt like the quality too much
thanks
thanks
