She's throwing a P0562 Code
So I go to get my jeep from the valet after a friends wedding and they said they can't start it. Then the valet said it just started when he came back with the charger but had not hooked it up yet. Now it has a hard time starting and is throwing a P0562 code for low system voltage. She seems to run fine once started and I ran it for a good two hours after the first time it happened. But it will struggle to start after you shut it off. Sometimes it will not turn over at all, then on the second or third attempt it will slowly crank right up. All I have on the battery is a 10K # winch and KC lights, but they haven't been used since I put them on. Well, I've turned the lights on to show off, but they haven't stayed on for more than a few seconds.
So just a bad batttery?
Mine died about 1 1/2 years after I bought it. It's funny this thread came up cause I went out today to go to work and the same thing happened. The dealer put in a oem battery to replace the bad one, but if you have another put in, I think it's just going to be a problem in 1-2 years. Those batteries they use suck.
