Side Marker Light Inop.
I just bought Smittybilt Fenders, and new side marker lights (similar to the ones Wayalife used when he chopped his stock fenders). Anyway, I plugged both of them in and the one side worked and the other didn't, so I swapped the inopperable one out for a new one, plugged it in to make sure it worked and it did. So I unplugged it so I could actually install it properly (ie. tighten the nut down). I accidentally touched the two wires together and heard a pop sound, like I blew a fuse. The light does not work now. However, I cannot find a fuse for the side marker lights. Any thoughts, possible fixes, and help would be appreciated. Thanks in advance.
Originally Posted by JK-Ford
First of all, a suggestion. Don't work on sophisticated equipment with the power on. Now for a possible fix: First - check all your fuses. Second - disconnect the battery and leave it sit for 10 minutes. Hope that works.
