Signal and marker lights
Good evening everyone. I’m going through bulbs like crazy on my signal, brake and marker lights on my 2010 Sahara Unlimited.. Also, my interior lights have started blinking and the outside temp and compass reading on the dash go in and out while driving. Any ideas?
Feesche, first of all welcome to the forum ! I bet you already know what we will say .... check yur grounds. No really, sounds like you have an intermittent problem with grounds for these light systems. If the grounds are compromised in any way , it will cause a higher amp draw and shorten bulb life if not just blow it up. Could possibly be from a mis-seated bulb in its receptacle. Could be corrosion build up on bulb receptacle. Good luck with this one!!
