Simple backup light?
I am adding a new rear bumper which does not have light holes (Bestop Highrock) and I am thinking it would be a simple thing to add one round fog light to the top of the bumper (or tire carrier, I will figure out exact placement once I actually have it) and then tie it into the towing wiring harness to power the lights. Easy wiring, no switch necessary, when I go in reverse, I will have extra light!
Anyone see any problems with my plan? Anyone done this?
So when you there your walMart lights on, did you run it off of the trailer wiring harness? Im curious because I was under the impression that a 4 pin trailer harness didn't work the back up lights.
I just tapped into the backup wire on the drivers side tail light. No problems at all. Works great. Also, this is where the trailer wire hooks up so I just ran the wires together for a clean install.
