Sirius Antenna Removal
Old Nov 14, 2010 | 07:43 PM
matzjeep's Avatar
Default Sirius Antenna Removal
I'm replacing my stock radio and want to remove the Sirius antenna also. Does anyone have any pics or info on where it is that would help me with getting it out?
I cant find anything that shows exactly where it is or how to get it out with my searches. Do you need to take the top off to get it out?
TIA!
Old Nov 14, 2010 | 07:51 PM
Facter's Avatar
I believe that it is part of the standard antenna. It is the extra wrap around it,
Old Nov 14, 2010 | 08:16 PM
rutdigger's Avatar
It's not the stock antenna. THat extra wrap is to tune the antenna. The SAT antenna is located here: Sat Tuner Antenna
Old Nov 15, 2010 | 04:50 AM
jollymon's Avatar
Great Picture. Just to help out real quick, that is the passenger side.
Old Nov 15, 2010 | 08:58 AM
Matt08jk's Avatar
I have installed one of those so I know what you will need to do. You will have to remove the passenger side lower door plastic molding and the plastic panels on the b-pillar. Then you will have to unzip all the sport bar cover like the photo shows to unclip the sat antenna block. The antenna may be tapes into the rest of the body wiring harness so you might have to cut that to remove. It routes up behind the glove box so you should remove that to get good access for removal.
Old Nov 15, 2010 | 12:58 PM
Bmorejeep08's Avatar
Not sure if the 10's are located where the 08's are. I have an 08 and it is located on the panel right above the head unit. The GPS and the Sirius antenna both are there.
Old Nov 15, 2010 | 01:00 PM
scouter4life's Avatar
Why not leave it where it is, that way it's still there for possible future use or resale? Leaving it in and unpluging it will not harm anything.
Old Nov 15, 2010 | 01:03 PM
db09JKU's Avatar
Don't believe that is correct, the module in that panel is the compass module. I had to reinstall it when I did my daystar panel.
Old Nov 15, 2010 | 07:05 PM
I have a rack as well and plan to replace it and place a magnetic antenna on the hood as it sometimes interferes with it, but mostly just when I have something on the rack. 95% of the time it's just fine.
Originally Posted by ukie jk
I could leave it there, but if I install a rack then if I want to run sat in the jk I will still need to address it's location. A rack with mesh will attenuate the signal if not stop it altogether.
Old Nov 15, 2010 | 09:11 PM
rutdigger's Avatar
Yes, passenger front
