Speaker help needed
Speaker help needed
Ok I'm in need of some help I have a 2016 jk with 130 radio and 8 speakers the system isn't bad if you keep the volume down to a normal level say 1/2 - 3/4 but if you crank it things gets ugly really fast . Now I have a 800watt planet audio compact subwoffer and amp that can run 2 extra speakers so first thing I'm going to do is install it and see what it sounds like with some bass maybe It will help but I have my doubts . This means I could get a really good set of speakers like focal PS 165V for the front and run them off the amp and disconnect the back set ? do you think this would work ok??? or would it be smarter to use the subwoffer and go with another amp and 2 sets of good component speakers ???. IM trying to avoid replacing the head unit until its out of warranty
