Speaker wiring
Old Oct 6, 2012 | 08:28 PM
JK yeti's Avatar
Default Speaker wiring
The harness in the rear tht connect to the sub woofer fell of and i cant find it so i spliced the wires but which ones go to which?
Old Oct 9, 2012 | 12:40 PM
2012JUS's Avatar
Do u have the factory infinity sound system in your jeep? And how did they fall off?
Old Oct 11, 2012 | 06:38 AM
JK yeti's Avatar
Yes i have the factory speakers and the owner before me took the rear subwoofer out and left wires hanging and the harness to the speakers got ripped of by my mountain bikes tire...
Old Oct 11, 2012 | 08:44 AM
JK-Ford's Avatar
DO you still have the broken piece? Just splice it back together.
Old Oct 11, 2012 | 08:57 AM
JK yeti's Avatar
I do have the piece but the 6 inch sub that im putting in came out of my room so i need to wire it without the harness.. There one postive and one negitive coming out of the sub and i dont need an amo because i have enough power commig from my aftermarket headunit
Old Oct 11, 2012 | 09:13 AM
JK-Ford's Avatar
Without an OE schematic. And if your not worried about it. Then just simply connect two wires. And if that doesnt work. Try swapping one wire till you find a combination that works.
Old Oct 11, 2012 | 09:28 AM
JK yeti's Avatar
Ive tried just aboutevery combination possible thats why im on here.. Haha
Old Oct 11, 2012 | 09:39 AM
JK-Ford's Avatar
If nothing worked, then you must have a pre-amp signal. Your going to need an amp. And a schematic.
Old Oct 11, 2012 | 02:19 PM
Rednroll's Avatar
That's why it doesn't work.
The OEM subwoofer connected to the external Infinity amplifier's outputs. So whoever installed your aftermarket radio, they had to make some jumper wire connections from the aftermarket radio outputs to the wires that connected to the speakers the other speakers in your Jeep. Those wires were originally connected to the OEM Infinity amplifier. Now they're connected directly to your radio. They probably didn't make a connection to the sub woofer wires because your aftermarket radio most likely doesn't have a powered sub woofer output, as well as there was no speaker in there anyways. Thus, your audio system is no longer connected to those wire...thus, the reason you don't hear anything when trying to connect that speaker.
To make this work....you actually do need an amplifier. You would connect the RCA Sub-woofer "Pre-amp" out from your aftermarket radio to an external sub amp. Then you need to connect that Sub amp to those wires that run to the rear.
Old Oct 17, 2012 | 11:19 PM
2012JUS's Avatar
Easy fix 5 channel amp and 9 wire. Bypass the factory amp altogether and amplify your speakers it sounds amazing and the infinity amp is junk anyway. That's what I did sound quality went from 0-1000% better!
