Splicing into headlight buzzer?
Old Mar 31, 2015 | 03:02 AM
BadBarret's Avatar
Default Splicing into headlight buzzer?
So yesterday I got some more lights wired up to my daystar lower dash switch panel and if you have a standard you know it's a tight fit when in 1st 3rd or 5th. I was just curious if it's possible to splice into the headlight buzzer so if you were to accidentally bump a switch on during the day and not notice the headlight buzzer would sound when the Jeep is turned off.
Old Mar 31, 2015 | 05:28 AM
ronjenx's Avatar
There isn't a buzzer to tap into. The computer senses the headlights are on and generates a tone. Assuming you have a relay to control the additional lights, you could wire it to a switched source of power so they will not come on when the key is off.
Old Mar 31, 2015 | 07:10 AM
BadBarret's Avatar
Hmm, that's too bad. Yeah I have relays but since it's not as easy as I thought it might have been, I'll just leave it as it is. Thanks
Old Mar 31, 2015 | 07:14 AM
ronjenx's Avatar
Here is a link to an easy switched source: https://www.jk-forum.com/forums/jk-e...source-191552/
