sPOD + OTRATTW switches?
Sorry if this is a dumb question. I've been looking around but haven't run across it yet...
Is the sPOD compatible with the OTRATTW switches which have 2 independent LEDs...one which turns on with the running lights and the other which turns on when the switch is activated? If they are compatible, is there separate wiring required in order to accomplish this? Thanks! Sent from my iPad using Tapatalk |
Originally Posted by gaap master
(Post 3921924)
Yes, they will sell you a kit with a button to turn on the "dash" lights. But mine don't have a separate wire. It is wired into other sPOD power--no extra install labor required. I plan to someday wire into dash lights, though. Right now, full bright lights by rear view mirror are a bit annoying at night.
Edit: Oh, while you're in there wiring things, consider adding the control with the gauge opening. I use mine for oil pressure. Bit short of an opening for some gauges, though, so research carefully if you opt to do. |
1 Attachment(s)
And the problem with the sepetate switch is you'll forget to punch it off, thus leaving the dash lights on while you go to eat breakfast, as I just did!
Attachment 556748 |
Thanks!
Sent from my iPhone using Tapatalk |
| All times are GMT -8. The time now is 09:28 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
