Starter Problem Help/Update "dont you just skip over the thread"!!!
Old Mar 1, 2010 | 02:00 PM
AndrewCote's Avatar
Default Starter Problem Help/Update "dont you just skip over the thread"!!!
so after hitting it a couple times lightly with a rubber mallet, the jeep started right up. so i ordered a new starter, and it came in today, the same day as the jeep died again. so i pulled off the heat shielding and the small yellow wire was disconnected. so i reconnected it and the jeep started fine again. do i still need to replace the starter? or is it ok? i have a feeling that it was just a disconnection problem
Old Mar 1, 2010 | 05:06 PM
AndrewCote's Avatar
i hope it stays on, ill keep the starter for a while just to see
Old Mar 2, 2010 | 01:35 PM
smallz46's Avatar
Make sure you use a lock washer when you bolt that wire back on, otherwise it's going to come off again. Seems like that was missed on production.
Old Mar 2, 2010 | 01:56 PM
Phantasm's Avatar
Vet: Army
Loose wires are no fun. Always reclean contacts with wire brushes/files etc. and make secure connections. I often use a Conductive lubricant. I use it on my boat and model trains where metal touches metal in connectors etc. Great on clamped wires too in places where the elements may cause corrosion.
Fair warning: if the grease can contact other electrical components it will cause a short.
Here is an example of the product:
http://www.micromark.com/SearchResul...tive+lubricant
