Starting Issue - no crank
Old Jun 7, 2025 | 05:16 PM
bill89052's Avatar
Default Starting Issue - no crank
Greetings everyone - I have a 2014 JKU. Twice now, I have jumped in the Jeep, turned the key and...nothing. The key turns to the on position and dash lights illuminate. Things chime. However, there is no crank when turned to run. Both times, after a few minutes the vehicle starts normally. It happened on 05/28 and then again today. I have used the car many many times between the 28th and today without issue. Very intermittent and seemingly random issue. Battery is good. Connections to battery are tight. Starter is less than a year old. Anybody seen this issue and know the cause/solution?
