Static in radio due to LED head lights
Old Dec 24, 2014 | 08:36 AM
JohnnyLS7's Avatar
Default Static in radio due to LED head lights
Hi Members
I just recently bought LED bulbs from extremterrain.com
Ever since I installed them and when they are tuned on
I get a lot of static in my radio, so bad I cant use it. Does
anyone have a solution for this problem. Thank u.
Old Dec 24, 2014 | 08:39 AM
DannyMalkin's Avatar
I would contact the company you bought them from and if they cannot fix it, return them. I always seem to use my radio so it would be a deal breaker for me if it didn't work.
Old Dec 25, 2014 | 03:49 AM
101gargoyles's Avatar
Former Member
No fix for your problem here but in my travel trailer I get the same problem when I turn on some but not other interior LED lighting fixtures. All the lights but not the entertainment system are on the same circuit
Old Dec 25, 2014 | 04:23 AM
budmanm3's Avatar
LED bulbs or headlights? Either way it doesn't sound right. I have LEDS everywhere and don't have any issues. Like it was said before, contact the company and work it out with them, maybe you got a bad batch or something isn't hooked up right.
Old Dec 26, 2014 | 08:25 AM
JohnnyLS7's Avatar
I contacted the company and they said all there led replacements bulbs do it... now I am on the hunt for LED headlights that wound cause radio static when they are turned on. Anyone have any recommendations?
Old Dec 26, 2014 | 08:34 AM
budmanm3's Avatar
Truck lites .. check Northridge 4x4..
Old Dec 27, 2014 | 05:39 AM
Wrangled's Avatar
I think I would reach out to Extreme Terrain and explain your issue. I am impressed with they're customer service, and if they can't tell you how to fix it, perhaps they will return them, or give you a credit towards a better quality set.
Old Dec 27, 2014 | 06:35 AM
rdavi's Avatar
What brand bulbs are these?
Old Dec 27, 2014 | 07:05 AM
Freedom21's Avatar
We have issues with LED lights emitting RF noise at work. The fix for them is proper grounding. Very different application, but sounds like same result, unwanted noise.
Old Dec 27, 2014 | 11:00 AM
darkknight1999's Avatar
Its going to be a grounding issue.
Is the HU the stock unit? Untouched?
