Stereo upgrade
1 Attachment(s)
Hi All,
I wanted to document my stereo build up. So far I'm putting in a Kenwood DNX691HD with a idatalink maestro. I got all the parts: Kenwood HU idata link maestro RR CH1 wire harness antenna wire adapter mounting kit Here's the wiring all put together. This is just the CH1 and the Kenwood wiring. There's two control wires to go along with this from the Maestro. I'll add some more pics as I get this done. |
2 Attachment(s)
I got this all done.
I heard a lot about the bracket just being removed for the top screw on the dash. I decided to try and cut it to re-use that dash mount screw. I cut the top wings off and the lower half just below the mounting screw holes. Attachment 597149Attachment 597149 It fit back in with no problem. Attachment 597150 |
2 Attachment(s)
I put all the wiring in. The maestro unit fits to the left of the air duct. There's an extra wire spliced into the amp turn on lead for the future. I also put in a USB cable for Maestro reprogramming. The USB input on the radio and the MHL cable are all run to the glove box.
Attachment 597151 The radio fit with the bracket back in. Attachment 597152 |
1 Attachment(s)
I was not sure if I wanted to use the Uconnect system or the Kenwood bluetooth system so, I ran the Kenwood mic up to the pillar. I'll be getting some double sided tape to secure the mic later. What does everyone else like to use? Uconnect or aftermarket?
Attachment 597153 |
2 Attachment(s)
Everything put in and the finished product:
Attachment 597154 Attachment 597155 Almost verything works! gauges work. Nav instructions display on the EVIC, but I don't know how to get them to re-appear if the EVIC is changed to another display, i.e. fuel economy. USB works, both Uconnect and Kenwood interface. I don't have the MHL working yet for my S5 because I need an adapter. I'm leaning towards using Kenwood bluetooth so I can use Pandora. |
Looks awesome! Kind of wish I would've went this route instead of the 730n stock radio. Where did you get the frame/bracket to make it fit so flush?
Originally Posted by Crush12JK
(Post 4056147)
I heard a lot about the bracket just being removed for the top screw on the dash. I decided to try and cut it to re-use that dash mount screw. I cut the top wings off and the lower half just below the mounting screw holes. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=597149"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=597149"/> It fit back in with no problem. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=597150"/> |
Originally Posted by immortalmetal
(Post 4056274)
Looks good! That's what I did with that bracket |
The double din units are taller and fatter than the stock stereo. There needs to be some modification to that "sub dash" bracket.
yes, the double din won't fit in the bracket. It needs to be removed to cut. The bracket holds the stock radio in place and has a screw on top to help hold the dash in place.
The brackets I got off of ebay as a kit with an antenna adapter and basic wire harness(which I didn't use). The brackets were Xscorpion brand. The only issue I had is that the screws provided with the Kenwood unit were not long enough to reach the threads in the side. I got some longer screws at my local hardware store. 4mm x 1.5 x 10 (I think). I went this route over a 430N because of 1 price 2 I wanted android integration (pandora, MHL). I have a backup camera to install too, but I'm going to install that at the same time I do new speakers and amplifier. Hopefully I only have to run wires once this way. |
