Stock Stereo Replacement Questions
Old Sep 9, 2011 | 03:24 AM
zfortna's Avatar
Default Stock Stereo Replacement Questions
I'm looking to gut the stock stereo and replace everything (Head unit, speakers, add an amp and sub) but have a few questions.
I have a 2010 2dr with the stock (non infinity) stereo system.
1) If I replace the head unit and run new wire to all of the speakers, do I need the PAC adapter? I dont have steering wheel controls or anything like that. Is there any side effect to doing this?
2) Is there a crossover that runs the front lower speakers and tweeters or are they driven separately with the stock unit?
Any other gotchas that I am missing?
Old Sep 9, 2011 | 05:21 AM
4WHLN's Avatar
I kept my stock (non infinity) head unit but replaced everything else I did not use a pac unit. Works great.
Old Sep 9, 2011 | 06:41 AM
shawlzy's Avatar
If you do not have steering wheel controls you should not need the PAC adapter.
Old Sep 9, 2011 | 07:25 AM
zfortna's Avatar
Thanks, that helps. Any idea how the front speakers are wired? I'm going to replace the with a component system but i'm not sure where the main feed from the head unit comes from to connect to the cross over.
Old Sep 9, 2011 | 11:48 AM
Flyswimmer's Avatar
There is no crossover in the stock front speakers (from at least what i could find), the tweeters have a capacitor in them. you will need to use the crossover that comes with the component system. I recommend Infinity Kappa's, I had them in my MINI Cooper and removed them so I could put them in my Jeep. I only had 300 watts driving a 350 watt system (4 speakers and no sub) it was like a concert hall. Maybe I can make the Jeep sound like and outdoor ampitheater
Old Sep 12, 2011 | 05:16 AM
zfortna's Avatar
Thanks for the help. I like the Infinity components, but I think Im going to go with a Polk setup since their db series is marine rated and that should help being in a jeep.
