Stop the Truck-Lite flicker
Like many others, I also have the flicker issue with my new generation LED headlights. I am getting ready to pull the trigger and purchase the correct harness from Susquehanna, then I found this from TLG-Auto for half the price. Has anyone tried this?
TLG-Auto | Top Line Group Automotive 350z Fiero Corvette NSX and MR2 Lighting and Accessories
Look under Truck-Lite and you will find their anti-flicker harness.
last week i installed some JW Speaker LED headlights. I also have the flicker issue ( i assume the TL and JW flicker are caused by the same thing, and should have the same solution). I have been looking for a way to get rid of it. What i've found so far is the $120 wire harness (no thanks). Then i figure i could probably make my own wire harness. Few feet of wire and a couple relays, the job would be done. Then i also found this product that i am considering from DDM Tuning. Its technically for HID lights, but i think it will work. I have been trying to contact their tech support to find out, but no one ever answers the phone. Its only $15, so i might just give it a shot. Take a look, http:// www . ddmtuning . com/Products/Error-Code-Eliminator-3-PAIR
It is very subtle, at least in my case. When the lights first got to me, one of them flickered like a strobe light. I had that one replaced I thought that was the flicker that everyone was talking about. But it is very subtle. When stopped, if you stare at the light in front of you (best if there is a car right in front of you) you can see it.
