Sub?
Old Mar 21, 2011 | 09:57 AM
Rapidfire's Avatar
Default Sub?
Two questions.
1. Can a sub be installed with the stock sound set up?
2. Has anyone seen a good mounting option for the 2 doors? I have seen the stealth pod case, but was wondering if there was anything else out there.
Thanks!
Old Mar 21, 2011 | 08:04 PM
Roman's Avatar
Default sub
Yes you can install a sub into the factory set up. You just need to get an amp that has speaker level inputs or a Line converter to turn a set of speaker outputs into RCA connecters. There are some good ones out there made by PAC. If your Jeep has the premium system you will need a line converter that you can install after the factory amp. You will need to install after the amp because the amp is what actually adjust the volume. Make sure you get one that can handle over a 50 watt signal.
Old Mar 21, 2011 | 08:47 PM
CLuBMieST3R's Avatar
+1 hes right.. i see you have the basic system without the sub..so you will have to buy a converter that converts your front or rear speakers (left and right channel) into a RCA output for your amp.. when you do this, your sub and speakers wont sound that great compaired to an aftermarket radio.. when the bass is turned up on the radio, your speakers will be pounding as well. it will definetly sound better than stock though.
imo if your considering going with an aftermarket radio in the future, i would hold off with the converter. you will regret pulling out the front speakers again to take off that converter, cause thats exactly what i did!
Old Mar 25, 2011 | 06:50 AM
Rapidfire's Avatar
Thanks for the info!
