Suggestions on lighting up the interior of a 5 ton
Old Jan 28, 2013 | 08:00 PM
Vladimer's Avatar
Default Suggestions on lighting up the interior of a 5 ton
Hi guys,
A bit off topic from the usual lighting questions. I have a friend of mine who runs a mobile tire shop in sprinters. They are currently outfitting a 5 ton to do the same. They were leaning to using 40" LED light bar off ebay, identical to the look of the Rigid Industries at a fraction of the cost. Considering the seller was advertising the item from everything off road to a simple work light, I am sure it would come with a fraction of the performance as well.
I figured the forum might have some good suggestions on good bright lighting they could use. The idea is to use a 12v system as they have a couple 3k volt syn wave inverters in it already running the machines and would rather keep this off that circuit.
My impression was that a single LED light bar would be a bad idea. You have way too much BRIGHT light coming from one place blinding the guy working on a machine and it is also coming from one source so it would create lots of shadows. My idea was to have 2 rows of 4 lights, something like the example below. A dome light I guess it's called?
hXXp://www lightingshowplace com/access-lighting-20633-orb-mfr-oil-rubbed-bronze-molded-frosted-contemporary-modern-two-light-down-lighting-flush-mount-ceiling/f740268
Please note that its an example of just a dome light. He doesn't want something that huge hanging from the ceiling all over the place.
Any suggestions?
Old Jan 29, 2013 | 07:38 AM
JK-Ford's Avatar
Originally Posted by Vladimer
Hi guys,
Any suggestions?
Something like this? There are other options like this. Different makes and models on the net.
Off Road Only LS-W6 - Off Road Only LiteSPOTZ 6 Light Under Chassis Kit - Quadratec
Old Jan 29, 2013 | 03:28 PM
Vladimer's Avatar
That is a good point actually! I didn't think of rock lights. There are a few that come ready built and are pretty simple to attach to whichever material is behind it.
