Superwinch running backwards?
Installed my Superwinch EPI-9S yesterday and it is running backwards. "In" on the hand control makes the winch spool out, and "Out" makes it spool in. The polarity IS correct at the battery. I don't want to re-label the hand controls except as a last resort. It would seem that I could reverse the wiring where it is landed on the terminals at the winch but I don't really know if that would work or which wires to move
. Any one have any suggestions? I will be contacting Superwinch tomorrow!
. Any one have any suggestions? I will be contacting Superwinch tomorrow!Look on your solenoids where the wires come from the controller input. You should see one wire is "shared" between the two of them (Probably RED, but it might not be). Dont touch that one. Now look at the other two wires going to the solenoids, the wont be "shared" Reverse them. Probably got messed up at the factory.
MAKE SURE YOU UNHOOK YOUR BATTERY BEFORE DOING THE ABOVE!!!!
Take your solenoid cover off,
The EPI has an intagrated solenoid, the wiring terminals are covered by the rubber boots, any idea which ones to swap?
It is possible that it got spooled out and back in the wrong direction?
Try letting out all the rope, then using "in" to respool.
(Unless the spool is clearly marked which direction is "in" and which is "out," in which case, I'm full of crap.)
Good point. On my cheaper Superwinch though they are quite specific which direction the rope goes in.
As for the OP, your solenoids are "integrated" but you can still get your cover off if you are so inclined, but if not I would just give Superwinch a call. You dont want to fry your winch and there is some serious amperage going through it.
If you happen to take your cover off though could you post a picture of the solenoids on here please? I am interested for another project i am working on.
Thanks
TH
These come with the rope needing to be installed by the owner. There is no arrow on the drum so if during install you wrapped the rope in the wrong direction to the control it would be going in the opposite direction when in use. When I put mine on I did this for a couple seconds until I noticed it. Just take the rope off and re-feed it in the correct direction.
