Switch panel into air vent panel
Would it be posible to make an custom switch panel for Arb Lockers , OBA etc, into the place from the air vent panel under the radio ??
With other words can it give problems if u remove the air vents ??
WHy would you want to completly get rid of your air vents? You must mean the flat space between the vents.
The vents come out easy with a twist. You can remove the dash face plate and modify it anyway you want.
Not sure if you know or not but... Daystar and other companies make prefabed rocker panels for under your temp controls, super easy.
