Switch wiring for arb OBA question
Thanks all for the help! My bracket arrived today so I'll probably tackle it tomorrow. There are a million wires there and if I read the schematic properly the only wires I run from the compressor are the red and the 4 power wires using a spst switch. I like where you put your switch resharp, I may do that.
I even thought about cutting a hole in the front seat riser (closest to the door) and mounting the switch as forward facing there. The only downside with that is you clearly see the backside of the switch unless you fab'ed something up to hide it. Good luck with your install. If you have any questions I think I'm subscribed on almost all your threads.
Resharp or anyone- where did you tap into a switched positive? Sorry for all the questions. The included instructions are limited. By the way, my instructions were incomplete so I called customer service and they emailed me a pdf of it, if anyone needs it let me know.
Well, I had already tapped in to the 12v plug in my dash when I installed seat heaters previously. I actually just retapped into the seat heater line to grab power. Forgot about that part.
Since you have to pass through the firewall anyhow, you might just have an easier time running a wire and tapping to a fuse in the fuse box.
I used an add a fuse on M37, I already had it there from my bully dog tuner
Attachment 667923
Attachment 667923
Well I finally got around to mounting the compressor today, what a pain! I can't recommend the JK Innovations brackets though, they use little rubber pins to mount one side and they were totally useless. Nothing a couple heavy duty zip ties couldn't fix though. I disconnected the abs plug before I disconnected my pos battery (I know, read the instructions first) and when I put it all back together my abs light was on. A quick trip to Chrysler took care of that. And they didn't even charge me. Wiring tomorrow. It took me nearly 5 hours just to mount the dumb thing.
