system
Old Jul 4, 2010 | 02:52 PM
thejeepjunkie's Avatar
Default system
i got 2 12's and a amp how can i wire up this system to the stock deck????? i just searched for any posts no luck thanks.
Old Jul 8, 2010 | 11:40 AM
what are rvc hook ups?
Old Jul 8, 2010 | 02:03 PM
EN2DIRT's Avatar
"RCA" looks like this. Usually stereo has female outputs and you use male cables to connect to it.
Old Jul 12, 2010 | 08:53 AM
ThaVisionary's Avatar
you'll need a line output converter that takes single from rear speakers and turns it into RCA output.. like $20 at Best Buy... Then a remote wire to the deck to turn the amp on when the radio is on and a power wire to the battery for the amp to have power and you are rollin!
Old Jul 12, 2010 | 09:27 AM
USAF_GroundRat's Avatar
No offense, but if you are not even familiar with what an RCA cable is, then maybe you should pay someone to install this system for you.
