TIPM removal to get to connections?
I need some help here please.
I started a thread about 3 weeks ago: "Help! Head Lights not working." https://www.jk-forum.com/forums/stoc...orking-235902/ What I'm trying to due is what a Chrysler tech to get my head lights working again. He said he lifted up the TIPM and disconneted the reconnected some connectors and my head lights worked for about 2 weeks. How does the TIPM lift out? Clips? Srews? If I dissconnect my battery, is it safe to do this? Out of my 3/36 warranty. Any help would be, well, very helpful. |
Bump.
I'm going to try this at 5pm EST. Any help or talk me outa it please.:what?: |
Disconnect the battery negative terminal before disconnecting any plug under the TIPM.
Push the 4 tabs inward, and lift the TIPM up. http://i776.photobucket.com/albums/y...IPMLatches.jpg |
Thank you very much ronjenx. You help so many on this forum. :beer:
Everything went smoothly. After disconnecting the negative battery cable, lifted the TIPM up and disconnected all connections including the heavy gauge ground wire. Cleaned with automotive connector spray cleaner/protector. Made sure connections were completly dry, then put it all back. (Head lights were working/not working with no rhyme or reason I can find, nor dealer) See my other thread: https://www.jk-forum.com/forums/stoc...orking-235902/ Head lights are working now. Only time will tell. |
