Help! Head Lights not working.
I turn my Head Lights on. They flash once, pause for 3 seconds, flash again. Does this 4 times then nothing until I turn ignition switch off then on. High beams don't work either.
Help!
Help!
Just checked for codes, have 4.
B162B left low beam control circuit low
B162F right low beam control circuit low
B1637 right high beam control circuit low
B1633 left high beam control circuit low
Sounds like a trip to the dealer. Just past my 36,000 mile mark for warranty. (37,200)
Took it to the dealer on 6-14-12. The tech said he lifted the TIPM up and checked connections and the lights started working normal. Said he did not want to replace the TIPM because it's expensive. Charged $99.95
I've checked the lights everyday and they have been working, until today. Same problem as OP.
He said if it does it again, the TIPM will need replacing.
What are your thoughts?
2) He should have at least ordered the new TIMP, because last I heard they are on major back order.
It has 39,000 miles on it. Thought my 3/36 was up? Powertrain is still under warranty.
Is it still under warranty? If so, could you tell or direct me how I could find out that my electrical or TIPM is still covered?
