tire sensor
Old Nov 8, 2010 | 12:27 PM
rozzman10's Avatar
Default tire sensor
My tire sensor light has been comin on in the mornings.. Gettin in the jeep about 28F .. But then later on in the day about 55F the light will go off.. I understand the physics of cold and hot and tire pressure change because of this but even if I put exactly 35 lbs in all five tires it still stays on.. Someone help!!
Old Nov 8, 2010 | 12:32 PM
ScruffyRubicon's Avatar
With the colder weather you are going to have to fill it to 35 psi at the average temp if you want to light to stay off.
Old Nov 8, 2010 | 01:01 PM
ronjenx's Avatar
Post the placarded tire pressure for your JK. I'll then post the warning threshold.
Old Nov 8, 2010 | 01:56 PM
09rubicon's Avatar
If its a rubicon the factory pressure is 37 with the threshold set at 35. Not sure about the X or Sahara.
Old Nov 8, 2010 | 06:53 PM
rozzman10's Avatar
is there a fuse or somethin i can pull an shut it off? i dont need a tire pressure monitor lol
