Trailer harness installation
Old Oct 14, 2009 | 02:38 PM
itasor's Avatar
Default Trailer harness installation
Installing a Mopar 4-plug trailer wiring harness in the next few days. Just plugs into the left tail light wiring. The instructions say to disconnect the battery before starting.
Do I really need to disconnect a battery cable just to unplug and plug in my tail light? If so, could I pull a fuse instead?
Old Oct 14, 2009 | 03:16 PM
LRBolt's Avatar
Knowing that I was just going to be handling connectors with nothing bare that could possibly short to ground, I didn't. But I'm not saying it's ok not to.
Old Oct 14, 2009 | 03:55 PM
itasor's Avatar
I think I will look for a fuse to pull just to be safe.
Old Oct 14, 2009 | 04:08 PM
Robar's Avatar
Hell, I didn't even read the directions and it never crossed my mind to disconnect anything other than the wire harness plug.
Old Oct 14, 2009 | 04:30 PM
cgtweet's Avatar
Default re
Same as Robar... I just plugged it in and routed to under the bumper. Worked fine.
Old Oct 14, 2009 | 04:37 PM
mjolnir's Avatar
x3 didn't disconnect anything, just plugged it in line and routed to the hitch, works fine
Old Oct 14, 2009 | 04:38 PM
dmhines's Avatar
X4 ... just plugged it and routed it as per instructions ... no battery disconnect.
Old Oct 14, 2009 | 05:51 PM
phljeeper's Avatar
x5, just installed a wiring harness an hour ago and didn't disconnect the battery or fuse. Just pulled the plug from the light and put the T connector in.
Old Oct 15, 2009 | 06:14 AM
itasor's Avatar
Cool, thanks guys
Old Oct 15, 2009 | 06:22 AM
BIGJ's Avatar
X6 DITTO,
