Truck light led headlight caused check engine light
Old Oct 7, 2013 | 07:39 AM
r3cluse's Avatar
I slapped my TLs in a few weeks ago with the anti-flicker harness. No zip ties, no tape, just plugged them in and put the grille back on. Maybe you got one that is defective from the factory. The circuit board inside could be out of whack.
Old Oct 8, 2013 | 02:30 PM
Lomax-dtl's Avatar
Originally Posted by jwilson2598
Hope this doesn't happen to me. Do you have the anti flicker harnesses or just the standard adapter?
The anti flicker
Old Oct 8, 2013 | 02:32 PM
Lomax-dtl's Avatar
Just got some new anti-flicker but same code
Old Oct 15, 2013 | 02:32 PM
r3cluse's Avatar
Do you think you nicked a wire and it's grounding out? Otherwise I'd swap out the TLs.
Old Oct 16, 2013 | 05:33 PM
Lomax-dtl's Avatar
No I just took it to the dealership and 6 days later they are still working on it lol
Old Oct 16, 2013 | 05:35 PM
Lomax-dtl's Avatar
It ended up being a wire that went from the computer? Or something it was all under warranty thank god!
Old Oct 17, 2013 | 01:41 AM
Kojack's Avatar
the zip ties and tape were used because i broke the tab on my factory harness taking the bulb out. I did both just to make sure that I did'nt break the other one as well. If I never broke that tab, I would not have needed none of that either.
Old Oct 17, 2013 | 07:49 AM
Ryan0260's Avatar
Zip ties and tape are a good idea anyways.
Old Oct 17, 2013 | 07:53 AM
Jersey_Devil's Avatar
My drivers headlight students won't come on so i zip tied the wire up and it works fine.....zip ties and duck tape are my favs! :thumbup:
Sent from my obama listening device
