Truck light led headlight caused check engine light
My new Truck light led headlight caused a check engine light, I have tried to redo the wiring but no good says the low beam is causing a high circuit.
first iver seen of this . ive had mine hooked up to a harness for a year now and never seen a code. Others have had theirs pluged right into the stock harness with no issues other then the flicker.
My malfunction light just went on I also have the TLs but I have had them on for at least 2000 miles and light barely turned on today going to the dealer in the morning will see what they say. I have 3000 miles on my 10a
I think mine tossed a cel once since I had them. But I re did the connections, ziptie'd, electrical taped, and made them more secure. No issues since. I'm using the tl anti flicker harness.
So the dealer just called me and they said the check engine light was because the computer was reading the wrong weight of oil. What's strange is that I only have just under 3000 miles and haven't changed my oil yet. They said it had an aftermarket filter as well??? Can the computer really read the weight of oil as I know some people run different oils with no problem? He said he is going to show me the filter and give me the codes but I'm just so confused as to why my 10A had a different filter and oil
Love my Truck-Lites!
