Truck-lites delayed and dim
So tonight I turned on my high beams and they flashed really bright for a second and then got in my opinipn dim. To be honest my low beams seemed to put off more light then the high beams. Also not sure if it is normal or not but when switching from high to low beams and vice versa there is a delay of about 2-3 seconds accompanied by the bright flash. Is this normal? I really feel like my high beams used to be alot brighter
They are less than a year old and have not been damaged on any way. Should I just call customer service?
Don't cha just hate it when they Fix and Run, I assume that your solution worked, cause her didn't come back looking for more help.
But your solution might just fix mine. Give me a few days, I will try to get back here to let you know if it fixes my one Truck-lite low beam looking dimmer than my other one. The High Beams look excellent.
