Turn signal light / Side marker light Question
Old Dec 19, 2023 | 10:38 AM
Backcountry Mike's Avatar
Default Turn signal light / Side marker light Question
Hello everyone! First post from a newbie to JK's, but not to Jeeps as I've owned 3 TJ's in the past. I'll miss my TJ's but I am really enjoying the creature comforts of my new (to me) 2016 JKU. My question is this - the previous owner installed amber LED turn signal lights on the front. All four work regardless if the running lights are on or if the headlights are on - they light up as they should. The problem I'm having is that when I use the directional to turn either left or right, only the two front facing turn signal lights work and blink, but the side marker ones do not. The same applies if the lights are in the off position. I'm figuring that the previous owner wired them incorrectly, which puzzles me because I believe that these are plug and play and no wiring would have been necessary. Any suggestions on what to look for? Is there any way to access those side markers without having to remove a couple of the plastic "rivets" that hold the black plastic sheathing inside of the fender well? I've attached a picture of what they look like as a reference.
