Turn Signals blink too fast
I just bought a used 2010 rubi. The turn signals blink too fast on both sides. The left one sometimes returns to normal when you hit the brakes, but not always. It appears that all bulbs are working. There are some mods that have been done. The previous owner installed Pilot LED tail lights. It also has Bushwhacker fenders with LED markers. I know a fast blink usually indicates a bad bulb, but all turn signals and brake lights appear to be working. Does anyone have any ideas?
There is no flasher in the JK. It is computer driven. The noise you hear is a mechanical relay, whose sole function is make the sound people are used to hearing for the blinkers.
Superbrightleds.com makes load resistors, which you can use to make the blinkers go back to normal. You would need to call them to find out which ones you would need. Make sure you mount them somewhere AWAY FROM WIRING. They get HOT and WILL MELT the wiring if mounted against it.
Anthony
