updating REN and Gracenotes...HELP!!!
I'm attempting to update my REN mygig. I'm about 5 updates behind on the REN software and God only knows how many on the Gracenotes. Have tried burning these updates from the unoffical mygig site, but the unit doesn't seem to recognize these updates. Can someone help me out and save me a trip to the stealership?
What media are you using? DVD-r or +r? What software are you using as well... And how are you formatting it? It took three different tries for my 730 to finally recognized the update
Cet99, I'm using Memorex DVD+R for the gracenotes. I used Memorex CD-R for the system update. Neither worked. As far as what software I'm using, I'm just downloading the zip file, unzipping it and then dragging and dropping to copy on the disk. I've tried copying the Gracenotes a second time using the software that came on the DVD+R, which I think was "burns". Dont even know what to tell you about the formatting info...
It's as I thought! The stealership charged me $50 to tell me my REN was up to date... What a bunch of crap!! Anyone who can help, please let me know. If you have the update disks for the REN and or the Gracenotes I would gladly pay you for them or pay to ship them both ways if you are willing to let me borrow them. Is there a way to contact Chrysler and get the update disks direct from them?
As for Gracenotes make sure you use a piece of software called NCH Express Burn it has a free trial for 30 days. (Never use the Windows software to burn any discs for the MyGig it will not burn the discs correctly.) See my instructions on the link provided below.
https://www.jk-forum.com/forums/show...52#post2949752 As for the REN software update the same thing goes as with the Gracenotes. NEVER use the windows disc burning software. I'll bet if you burn the update with NCH it will install fine. There will be no more updates for this device because the production has ended and they are no longer built. Latest Software Application for REN is 9.292 |
mygig update from harmen becker.
Originally Posted by Hotspur
(Post 3072956)
Originally Posted by whpony96
(Post 3073696)
MyGig Gracenotes Update v4620 US/Canada/Mexico As for the REN software update the same thing goes as with the Gracenotes. NEVER use the windows disc burning software. I'll bet if you burn the update with NCH it will install fine. There will be no more updates for this device because the production has ended and they are no longer built. Latest Software Application for REN is 9.292 And is the latest Gracenotes for the REN 881 ? I just upgraded from 534 to 881...and have the 9.292. but I noticed that there the FRONT CONTROLLER: NA |
OK SOOOO,
REN should be 9.292 and gracenotes 881 but now I have a question still about UCONNECT Attachment 550189 and what are the FRONT CONTROLLERS? |
You should be able to use the 4620 or whatever the latest RER Gracenotes is to update your REN. the application software is different between them, but the Gracenotes are the same.
Easiest way to update these is getting the CD's from the guy on fleabay, I've done this on 2 different nav's works great. About $20
