Upgrading Headlights
I am trying to find the easiest way to change the light bulbs in the stock headlights. My hands are too large to access from behind, can I take the grill off and access from the front?
Yeah. There are six little plastic thingies that hold it in from the top. Open the hood and you can see um. I just take my knife, pry the center up and out, pop the outside part out and that's it. Then, just grab it from the front right around each headlight opening and pull. Be careful about the turn signal harness. Disconnect them before you triy to remove the grill entirely. You'll see. It's easy.
