VIAIR Heavy Duty Install in my 2-DR JK ...
Old Apr 29, 2012 | 10:53 AM
dmhines's Avatar
Originally Posted by minime
Looks great! Let us know if there are any heat issues with the compressor inside the tail light housing?
It does get toasty in there when it's running. Melted the cheapo Red Rubber Airhose I get from Lowes so I had to reroute it down to the tank. I'm thinking it can't be any hotter than how hot it gets under the hood of a JK!
Old Apr 29, 2012 | 10:57 AM
minime's Avatar
And I would see if you could make something, so that the air hose could attach outside the storage compartment. Reason being it would suck to have to move gear out of the way to access the hose.
Old Apr 29, 2012 | 11:07 AM
minime's Avatar
I wonder if a small fan could be installed to help with cooling?
Old Apr 29, 2012 | 11:44 AM
dmhines's Avatar
Until it trips the Thermal overload Protector I'm not gonna worry about it.
Old Apr 29, 2012 | 12:18 PM
minime's Avatar
I was more concerned about the wires and other stuff inside the tail light area. Because I'm not to sure if that stuff is designed for that much heat, unlike all the stuff installed in the engine bay area?
Old May 3, 2012 | 04:02 PM
Air Werkz's Avatar
Former Vendor
Originally Posted by Sahara_Maverick
If memory does not fail, Viair does not recommend mounting the compressor sideways. That is, with the cylinder sideways instead of vertically. They claim it shortens its life.
Ideally you will want to mount the compressor right side up, but if mounted on it's side it should be Ok. Completely upside down is not ideal.
You should be Ok, it is a very stout compressor.
Old Jan 4, 2013 | 06:44 AM
GoBig's Avatar
Holy Crap ... mounting that compressor in there was not an easy task! You need small hands, strong fingers and lots of patience!!!
How did you run your electrical? Also, what size wire(s) did you use to the battery?
Old Jan 4, 2013 | 04:59 PM
dmhines's Avatar
I used the wire included in the kit .. ran power all the way to battery .. brought it up through existing grommet. It isn't pretty ... somebody I'll put some wire wrap on it.
I've had this installed for a while now. Works great. No heat issue. I updated my install and ran the intake tube up through the same grommet with filter sitting on top in cab so it brings in cool air when compressor is running.
I am also using the tank for some air horns I installed.
Old Jan 4, 2013 | 05:45 PM
GoBig's Avatar
Thanks for the response!
