"Vision X" solo LED fog light replacement
Old Sep 5, 2011 | 06:50 PM
DONKEY-PUNCH's Avatar
Default "Vision X" solo LED fog light replacement
Found this new product for our rigs!
Anyone running these LED fog lights?
Old Sep 5, 2011 | 07:23 PM
joecarioscia92's Avatar
Is it for 2010 + or no? I haven't seen any fogs that would work for my 2010 because of the stupid computer.
Old Sep 5, 2011 | 07:29 PM
Per "ok4wd.com" they state the fog lights are for 2007-2011 jk's. 900 Lumens each produced for $78.95
Old Sep 5, 2011 | 07:30 PM
maverick0862's Avatar
that price is just for the brackets to mount the lights, add another $237 for the led fogs to go in the brackets
Old Sep 5, 2011 | 07:35 PM
Oh shit! I didn't catch that.
Old Sep 5, 2011 | 07:43 PM
What's the deal with the computer, when you attempt to change the fogs?
Old Sep 5, 2011 | 07:58 PM
ssease's Avatar
Does anyone know how many lumens our stock fogs put out?
Old Sep 5, 2011 | 08:23 PM
Incandescent lamps produce approximately 15 lumens per Watt. So how many Watts do our fogs produce?
Old Sep 5, 2011 | 08:57 PM
snopro269's Avatar
Yeah I never heard anything on this either?!?
Old Sep 6, 2011 | 05:32 AM
WhosUrBuddiee's Avatar
They use a CAN-BUS network that supplies a pulse width modulated signal. Rather than a constant voltage signal it is actually a series of pulses. With incandesent bulbs there is an after glow when you remove power (think of turning off a regular light in your house) so you dont notice the pulses. This actually extends the life of your bulbs because they are not on constantly. But LED bulbs do not have an after glow and turn off immediatly. So the modulated signal is actually visiable as a flicker. The only way to correct it is to install inline capacitors to even out the voltage signal to the lights.
