What happens if... (winch question)
Hello!!
I have a question now that i have my first winch (Warn 9.0RC).
In a normal winch installation, you install the winch on a front bumper, and run the wires to the battery and plug + and -. That's pretty much it. Then, to use the winch, you plug the remote control. So, there's no power to the winch if the remote control is not plugged in.
My question is... what happens if the winch goes underwater? let's say crossing a river that could get to your bumper, or maybe not so deep but the you fin a hole deep enough the put the bumper under the water or any other condition like this one happens...... is everything OK? i mean, no problem with the battery or the winch itself or any other electrical component for submerging the winch?
Thnx
Thnx
Yeah but my question is not about the winch itself. I'm more worried about the connections to the battery. If you submerge a winch, you are submerging to wires that go to the battery... sorry for the ignorance, but for some reason i am confused if that's a problem or not.
The pos and neg wires running to the battery will be fine. Over time a lot of exposure to different elements can make them brittle or corrode etc, but they should be ok.
Keep clean and dry when not in use.
Keep out of direct sunlight if possible.
Clean with:
Compressed air ( Not more than 30psi )
Or vacume cleaner ( prefered )
Use solvents that are friendly to rubber and plastic.
Hope this helps.
Thank you man
X2, well sorta! The electrical components of the motor are fully insulated all the way up to the carbon brushes. And the relays in the controls should be fully silled. So if you take care of your winch, water shouldn't be a real problem. If you don't already know. I'll list some basic maintenance procedures for taking care of electrical motors and components.
Clean with:
Hope this helps.
Clean with:
Hope this helps.
bingote -
I installed my XRC8 by running the pos and neg directly to the battery without some lockout. While I didn't have the winch underwater like you are describing, NY likes to REALLY salt their roads.
What happened to me was the wiring from the remote port to the solenoid corroded and caused the winch to spool backward. It snarled the cable, which caused it to kink, scratched up my bumper, and I had to use a six foot breaker bar to loosen it enough to unhook it from the D-ring.
All-in-all, I'd recommend putting some kind of switch on the main power feeds.
I think what the OP is eluding to is arcing? The DC voltage that the jeep runs, isn't enough voltage to allow the water to complete a connection. Unlike household AC voltage.. In theory you can submerge your battery 10 foot deep in water and it shouldn't have a problem as most batteries are of sealed design now. Now the rest of the jeep in that same 10ft of water will not fair as well.
