Why the heck does the hood need a grounding strap?
Old Oct 27, 2011 | 08:04 PM
troyboy's Avatar
Question Why the heck does the hood need a grounding strap?
Anyone know what the point is for having a grounding strap to the hood?
I never noticed it there until I was wiring up a fuse to my winch when I accidentally used my socket wrench to short out my battery against the strap. Scared the crap out of me.
Old Oct 27, 2011 | 08:14 PM
jeepjunk's Avatar
Of the top of my head and without lifting the hood my guess would be they grounded the hood due to the engine compartment light being attached to the hood itself?
Just my guess though.
Old Oct 27, 2011 | 08:28 PM
troyboy's Avatar
That might be it. I don't have a hood light though.
Old Oct 27, 2011 | 09:32 PM
JK44M's Avatar
I read that the hood is grounded because it keeps static out of the radio. If the hood is not grounded correctly the rattling around can causes static charges which causes pops and snaps in the audio. Not sure if this is true, just something I read.
Old Oct 27, 2011 | 09:38 PM
sringer's Avatar
i have been wondering this myself. thanks for posting about it
Old Oct 27, 2011 | 09:42 PM
Cdyspeed's Avatar
It's to keep the 1.21 jigawatts under control
I agree that $h!t can get out of control
Old Oct 28, 2011 | 03:48 AM
JK-Ford's Avatar
I'm sure that there are other reasons that I may be unaware of. But rust prevention is one of the reasons to bond all the metal parts together.
Old Oct 28, 2011 | 10:03 AM
DonP's Avatar
i know in airplanes its for lightning and static every door has a grounding strap on it
Old Oct 28, 2011 | 10:14 AM
ronjenx's Avatar
The JK under-hood lights I have seen have both positive and negative wires, and the case is plastic.
Old Oct 28, 2011 | 10:39 AM
JK-Ford's Avatar
I couldn't think of the term earlier. But this ground strap is most likely related to "Equipotential Bonding". And it basicaly serves two purposes. One , as I mention earlier, rust prevention. If two different metalick surfaces that are in contact with one another happen to carry different charges, current will flow from one to the other. This current flow promotes rust. Two, the equipotential bond also serves as a grounding plane for electrical systems. Not necessarily to carry the return for electrical circuits. But to facilitate electrical circuit safety. Basicaly, if a hot wire comes in contact with the hood, it will blow a fuse because it is grounded. This is my best guess.
