Will this radio work?
I just picked up a 2012 JKU which has the 130RES in it. It has UConnect, bluetooth and the steering wheel controls. I have located a MyGIG, part #p05064400AI. Now, I am wondering if this will work in my JKU as a direct replacement? If so, will I lose any capabilities, such as the steering controls, bluetooth, UConnect, etc....
It will wok but you will loose your u connect and this unit requires two antennas one each for the sat and nav.
The easiest unit for your setup is a high speed RHB 430N which is a plug and play.
