Will these fog lights work?
Old May 14, 2011 | 05:12 AM
Flaxbourton's Avatar
Default Will these fog lights work?
I bought my 08 4 door rubi jeep used and it didn't have the stock fog lights. I just purchased a PSC Brawler Lite bumper and it comes with holes for integrated fog lights, presumably sized to fit the stock headlights.
I found the below on ebay and was wondering if anyone knew whether or not the brackets, wiring harness, and size are actually correct. It says it fits my jeep, but you never know....
Thanks!
Ebay Fog Light Listing
Old May 14, 2011 | 11:49 AM
BrunosJK's Avatar
Yes they will work, its after market wiring so it will not wire up like the factory setup.
Old May 15, 2011 | 03:58 AM
Thanks, got them in the mail! I just read that they don't come with any wiring harness or bulbs, heh, oops. Now I gotta figure out what bulbs will fit :/ Anyone know if a standard 1156 or 1157 LED bulb will plug in to a standard fog light housing?
Old May 15, 2011 | 10:35 AM
Ericker's Avatar
I use these in mine and really like them.
http://www.quadratec.com/products/97...googlemerchant
They plug right up to the factory wiring for my 2009. I'm not sure how you're planning on wiring everything up, but there is a factory harness that you can pick up that comes with a new steering wheel stalk with the fog light switch. Only downside is that you have to have a dealer flash it in. I'm really happy with the factory setup. Also if you go this route look at installing cruise control if you don't have it since you'll be working around the steering wheel already. You can buy the parts for under $100 and that does NOT require a computer flash to work.
