Windsheild mounted KC hi-lights
Old Dec 15, 2009 | 04:37 PM
Raf's Avatar
Raf
Default Windsheild mounted KC hi-lights
I was thinking about getting these. Only problem is that I was told that if I have these installed the wires would either be showing from the rear of the light assembly or a hole would have to be drilled and ran through the body so the wires are hidden. The only problem I have with that is after time rust and rot happens. And I dont think Im too keen on that idea. Anyone have any advice or already have the lights mounted up there and have run into problems? Or should I just go with mounting them on the bumper?
Old Dec 15, 2009 | 05:03 PM
scbesse's Avatar
Mine are great no drilling required at all.do a search on kc write up. Cheers
Old Dec 15, 2009 | 05:11 PM
Raf's Avatar
Raf
Great SCB thank you! Is the wire very noticeable from the rear?
Old Dec 15, 2009 | 06:09 PM
TheonlyREDhead 2008 JK's Avatar
No it tucks right down in the cowl piece by the wiper arms, not that noticeable at all.
Red
Skip also just did a great write up on this as well. https://www.jk-forum.com/forums/jk-write-ups-39/definitive-windshield-light-installation-write-up-111452/
Old Dec 16, 2009 | 01:05 PM
Muffins's Avatar
Hardly notice them behind the lights, and I would highly recommend upgrading to the the Lightforce 140s or 170s, I had the KCs, the Lightforce lights blow them away in distance and clarity (white-ness?)
Old Dec 16, 2009 | 01:13 PM
chrisfetz's Avatar
I have the KC's mounted on the windshield and on the bumper. I can't complain with the quality of the lights, and the wiring barely shows, just tuck it under
Old Dec 19, 2009 | 05:20 PM
CLOTAGAMES's Avatar
How do you have your Lightforce's focused-seems like they work just like a maglight flashlight-If I rotate them for a wider beam-I get a dark spot in the middle. i have been running them more like a pencil beam.
