Which windshield mount for KC slimlight?
when i took the screws out on the windshield, these little plastic caps were under them. i put them back in and it gave me a tiny boost behind the bracket so it wouldnt scrape. i then put a small level on them and screwed them on. the kc brackets have a thick gloss paint so even if it did connect it wouldnt scratch the jeep. you could probably put a paper towel behind the bracket and just pull it out after you get the screws in. it worked great. i got it done in about 5 to 10 minutes. what took the longest was driving to town to pick up the torx bits that i forgot. ill see if i can get a better pic of them later.
That explains alot.
I contacted Smittybilt, and they claimed to not make them any more.
I also noticed that 4wd.com had them on clearance on the webstie and they are gone as of today.
I just got a set off of ebay, which was about $15.00 more than getting from 4wd.com.
![Smile](https://www.jk-forum.com/forums/images/smilies/smile.png)
