WindShield Nuts??
Old Dec 8, 2020 | 04:59 PM
MKempf's Avatar
Default WindShield Nuts??
I'm in the process of installing a Light bar across the windshield. I had trouble getting 2 of the 12 Torx bolts loose they are just spinning. ( Bolts M8-1.25 Part Number: 06508953AA ) I have searched the forums and I know I need to drill out the bolts and fold down the windshield to get the drilled out bolts removed and get to the nuts. I have already ordered new Bolts so that I would have them prior to embarking on this fun repair adventure! LOL But my question is does anyone know what the part number is for the nuts that the bolts screw into? From what I found on the net they are just held in place by some metal fingers and you can bend them back and get the nuts back in position according to the forums but I would like to order a few of the nut's so that I have them available if the old ones are to damaged, rusted, or just junk to use once I'm done drilling the bolts out. I might not need them but I would like to have some of these nuts on hand so that once I get into this project I don't have to stop and search for something that will fit I would rather have the correct parts on hand and get the job done right. This Jeep is my daily driver and I live in Michigan so it is cold right now so once I start tearing everything apart and folding the windshield down I would like to have all the proper pieces on hand that I may need so I can get everything put back together properly and not have to drive around looking for parts.
Any info on these nuts would be appreciated:
Thanks for your time and Help!!
Old Dec 9, 2020 | 10:23 AM
Chris_f's Avatar
You might want to try rivnuts like this video
chris
Old Dec 9, 2020 | 02:19 PM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
Rivnuts can spin also if they somehow don't crush as tight as they should. I would MIG weld cage nuts in there if you can get to the back or ordinary nuts in an enlarged hole. Either way you need to touch up the paint.
Old Sep 20, 2021 | 08:12 PM
MKempf's Avatar
Default Repaired
I replaced the stripped out Torx bolt. I had to drill out the torx bolt then completely drop the windshield in order to get to the nut. You can reach it from the bottom of the windshield once its leaning forward. It wasn't the easiest thing to do but it is definitely doable. Took me about 2hrs to accomplish everything. I ordered new torx bolts from Amazon and ordered some square nuts to fit.
