Wipers won't turn off.
Hello All.
I've got a 2008 Cherokee 2.8cdr sport and its succumbed to the wipers won't turn off, no turn signals, lights won't turn off, rear wash and wipe not working.
All other electrics are working fine.
Tried disconnecting battery routine 3 times - no change.
Disconnected all wiring from multifunction switch - wipers still running when ignition is on.
Swapped out the TIPM - issues unchanged.
HELP!
HELP!
What started the problems? That usually helps for a starting point. Other than that, I would start troubleshooting. Pick something like the wipers and slowly work back along the wiring. It may be you have a short in a wire or wire bundle (rubbing can cause wire insulation to come off) somewhere. You can find a wiring diagram that will help chase it down as well.
