Originally Posted by webejeepin
(Post 4114158)
... Guess I'm old school... cable ties at equal intervals. (Broadcast Television Engineering will do that to a guy) ...
http://cdn.makezine.com/uploads/2009...blelacing1.jpg I agree about soldering in this case, though in my background (27-1/2 years avionics maintenance) soldering was generally avoided for wiring runs. But that's because the vibration of aircraft is rather hard on single strand wire (which is what multi-strand wire becomes when you solder a connection). |
Originally Posted by Dave L
(Post 4114152)
So you can have multiple wires on one end of a crimp connector
(Post 4114158)
Multiple wires in a crimp, should be fine, you might need to size the crimp to accept x amount of cables based on their wire gauge I would suspect.
And as Mark stated, voltage drop is an important consideration. Most guys use a 5% drop since auto accessories are designed for 12V and the alternator puts out 13.8V. I have always used a 2% drop because I tend to over-engineer for safety when it comes to electrical and 2% is the non-automotive standard I believe. |
What happens when the pigtail on the lights are of a smaller gauge than desired and then are in a sealed housing?
(Post 4114297)
(Post 4114297)
(Post 4114287)
I guess I'm older school, LOL ... I agree about soldering in this case, though in my background (27-1/2 years avionics maintenance) soldering was generally avoided for wiring runs. But that's because the vibration of aircraft is rather hard on single strand wire (which is what multi-strand wire becomes when you solder a connection).
There's a few guys at work that will only lace, I sure do respect the craft that goes into this work. That's putting love into your work. Most others it's release-able cable ties done. See if I can dig up some photos of what a 1026 x 1026 router looks like all wired in nice and neat. |
(Post 4114536)
Wow. Cool, lacing! There's a few guys at work that will only lace, I sure do respect the craft that goes into this work. That's putting love into your work. Most others it's release-able cable ties done. See if I can dig up some photos of what a 1026 x 1026 router looks like all wired in nice and neat. |
(Post 4114565)
That wasn't actually my work in the image, though it is how I used to do lacing on ... C-47s. Yeah, I'm that old. ART-13 transmitter and BC-348 receivers. Vacuum tubes. Discrete components. Air dielectric variable capacitors the size of an egg carton. Miss those days.
I'm on the SATCOM side .....fleet of 17Ghz 2 kW single and multi stage collector klystron tubes. Yes, tubes still in today's world of smaller. When you need brute force power in a narrow band nothing beats it, oh and taken care of they last years. Dig the avionics...never made it past broadcast lol |
(Post 4114284)
P1TBU11. Check out this link http://www.bulkwire.com/wireresistance.asp it will tell you what size wire to use. Simply put in the total length of cable (including the length of ground wire) and enter amps (watts/voltage) and voltage.
Originally Posted by P1TBU11
(Post 4114581)
So, do I just take the advertised watts and divide by 12 to get amps, or do i need to use 13.85?
